Old Feb 5, 2009 | 04:05 PM
  #62 (permalink)
BrianBrave's Avatar
BrianBrave
<--- Huge Horsepower
Default Re: What Else Do You Want?
Originally Posted by Trbokmro
The only issue i see is the clutch setup, i know it's usefull to help regulate pulley acceleration..... what are your thoughts on removing the clutch setup? has it been done? that would easily knock 3/4 of the price off.
A simple test would be to "switch" the pulley on at engine start - this could be done with a simple (and reversible) modification in the fuse box. I did a similar type mod to run my IC pump when the key is switched "on".
I think you may discover some tune issues at idle and low RPM - but most off all - - extremely elevated IAT's.
Seems like we always get back to that Bocsh ECU.......
