Re: Difficulty Starting + Solution & Dealer Fix
If you search and find my thread on the Crank Postion Sensor you should find the part number.
It is located on the back of the engine, drivers side, just above the bell housing. You need to take the drivers side intake off to have a nice clean look at it. The locking clip for the connector is on the passenger side of the connector. Squeeze it and pull the connector off. E8 torx socket for the bolt. Carefull, dont let that little sucker drop. It could be hard to find. I didnt have any trouble reaching down and holding it while pulling the socket back out with it. Then just pull out the sensor.
MikeR
