Thread: Spring help
Old Feb 7, 2009 | 09:37 PM
Thumper SRT6's Avatar
Thumper SRT6
Thumbs up Re: Spring help
Originally Posted by cgocifer
Does anyone have the correct torque numbers for the A-Arm and shock bolts and nuts? I'm planning on using some blue Loctite, but I'd like to be sure my shi* doesn't come apart on me on these crappy roads.
Found what you're looking for in the service manual PDF (found in the SRT6 Documentation thread). I've posted the numbers here, but there are nice tables on the mentioned pages.
From the Service Manual PDF:
FRONT SUSPENSION (Section 2 - 14, page 38 of the PDF)
TORQUE SPECIFICATIONS
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Front Shock Absorber Upper Nut 18 13 159
Front Shock Absorber Lower Nut 55 41 487
Front Sway Bar To Lower Control Arm Nut 20 15 177
Front Sway Bar Bushing Nuts:
M10 40 30 354
M8 20 15 177
Front Sway Bar To Frame Nut 60 44 531
Upper Control Arm Joint To Steering Knuckle 45 33 398
Clamping Nut 11 8 97
Lower Ball Joint To Steering Knuckle 140 103 1240
Lower Ball Joint To lower Control Arm 105 77 929
Upper Control Arm To Body Nut 65 50 575
Lower Control Arm To Frame Nut 120 88 1060
REAR SUSPENSION (Section 2 - 44, page 68 of the PDF)
Description N·m Ft. Lbs. In. Lbs.
Stabilizer Link to Stabilizer Bar 30 22 266
Stabilizer Bar to Stabilizer Link Nut 20 15 177
Bolt, Stabilizer Bar Clamp 20 15 177
Upper Shock Nut 18 13 159
Shock Absorber to Lower Control Arm 55 41 487
Rear Axle Carrier Nut 90 66 797
Rear Axle Carrier Rear Nut 90 66 797
Rear Axle Center Assembly At Front to Rear Axle Carrier 50 37 443
Rear Axle Center Assembly At Rear to Rear Axle Carrier 110 81 974
Lower Control Arm to Rear Axle Carrier 70 52 620
Lower Control Arm to Wheel Carrier 120 88 1060
Camber Strut to Rear Axle Carrier 70 52 620
Camber Strut to Wheel Carrier 70 52 620
Trailing Link to Rear Axle Carrier 70 52 620
Trailing Link to Wheel Carrier 70 52 620
Lateral Link to Rear Axle Carrier 70 52 620
Lateral Link to Wheel Carrier 30 22 266
Track Bar to Rear Axle Carrier 70 52 620
Track Bar to Wheel Carrier 70 52 620
