Originally Posted by MrPedalsworth
So I'm trying to find out if anyone tried to put the 6spd in an SRT-6?
Either using the 6spd out of the standerd Crossfire or doing some custom work?
I talked to the guys at RENNtech and they want $20,000 to put a 6spd
in an SRT-6!?!?!?
I know i'm not the only one that thought of this or wants to do this?!?!
I'm sure it's much more involved then swapping in the 6spd in from
a standerd Crossfire with clutch pedal assembly. Will the manual tranny from a Crossfire take the hp?
Is it a clutch issue? Is it not a strong enough clutch? Is there a stronger Mercedes
6spd/ clutch that would swap in?
Is it just a waste of money? But honestly, why make an SRT-6 with out a
6spd?????
Any thoughts?
Save your money and invest about 400 Euro in the following:
VAETH -a well known Mercedes Benz Tuner - made a spezial software for the crossfire SRT6 automatic gearbox.
If you use the hand-switch-mode of the automatic transmission, you have the following advantages:
- Automatic gearbox switches immediately without delay
- Automatic transmission switches to a very wide speed range
- Consumption is reduced. You can drive with very low engine speeds.
-The transmission does not switch automatically to the next higher gear.
- The automatic transmission only switches back when the engine speed falls below 1000 rpm
The new gearbox software is much better as the useless series software.
www.vaeth.com (Mr. Welzbacher)
