Old Feb 8, 2009 | 02:06 PM
jturkel's Avatar
jturkel
Default Re: ? Best 178 Pulley Kit ?
Originally Posted by hawksview
I have the 178 ASP also and havent had a problem with it at all.Just curious when you spoke with code 3 about the mid sized pulley if he said it will require a belt change or can you still get away with the stock belt?
same size belt....but you might need to get the Code3 Belt Wrap Kit when it is released. If it is not required, I'm sure Brandon will highly recommend it.
