Re: test drove an srt6 today
Yes, turn off TC and floor it again. Just hang on. Don't floor it around a corner with TC turned off. You will end up sideways. They only had 3/36 on SRT. Check to see in service date. That will tell you what you need to know. Regarding convert top. Go into boot, trunk. There is a flap/seperater. This must be folded forward and up. There are two pegs on upper sides that fit into slots. Those pegs must be slide in and locked into place. Top should work. If out of warranty, I suggest buying extended one. You can do search. Numerous threads. I bought from Chrysler. It was the least expensive I found. Plus they have to honor it. They hate dealing with other after market warranties. Not that SRT's break a lot, if they do, it's not cheap.
