Re: How do I get behind the ashtray?
This isn't very easy. I had to get mine out in order to re-attach the light to the ash tray as it got moved when a chap fitted my mobile phone car kit. In order to get to it you need to remove the radio, remove the plastic dash surround, remove 4 screws holding the center console in, remove the gear stick surround and center console cover to get to the bottom two screws, then push the lower section on one side to take it out diagonally. It isn't that easy as you have to pull so much other stull out first but once you've done it once it is ok.
