Originally Posted by rodimus
Is the camber a part? Or is it something that you can adjust?
It is to my understanding that if the camber is off your wheels will have uneven tread wear.
From the article:
Camber is the angle of the wheel, measured in degrees, when viewed from the front of the vehicle. If the top of the wheel is leaning out from the center of the car, then the camber is positive ,if it's leaning in, then the camber is negative. If the camber is out of adjustment, it will cause tire wear on one side of the tire's tread. If the camber is too far negative, for instance, then the tire will wear on the inside of the tread.
