Originally Posted by SRT6 Gang Member
I need to data log more on the ¼ track but the three passes I did log were telling. Heat is more of an issue on the ¼ track compaird to the 1/8 track because of prolonged WOT. My first pass was 12.20 and eng temps reached 194 deg while IAT hit 160. My second pass was a hot lap and I trapped 12.37 where eng temps reached 207 while IAT hit 170. Due to that heat, timing was pulled, mph was reduced, boost fell and it reflected in my ET. Those things happen on the 1/8 track but not as extreme, talking hundreds and not tenths. I’m going to go with colder plugs and Split coolant reservoirs too see how that helps.
I wonder what max temps are hit with the 178 or Code 3 pulley….. Based on your sign, that tune is killer
Sometime before summer I'll go back to the 93 tune just because I plan to drive it more. It's officially a daily driver now. Today I drove it in the rain with stocks on of course. Only the 2nd time the car has been hit by rain since I've owned it. Now onto IAT's I don't log those, but would like to. I go off my needle and rarely hot lap. My problem is I can only log at test n' tunes, data loggers are illegal in my class so I don't use it in competition. I wouldn't do any cooling mods just yet. Just lay a bag of ice on the supercharger or spray chilled water over it. It cools in 10-15 minutes. At least good enough for the strip. Still stock plugs and wires too. No exhaust mods either.
