Originally Posted by SLK32Germany
I think with a 178mm and WOT it is impossible to get IATs of 105-113 Degr.Fahrenheit, even with a split IC system,CM30 and LET HE ... IATs must be higher in my opinion.
I had the computer hooked up the other night and was seeing 97-105 on WOT bursts, but it was 40 degrees. I will see if I can get do some screen shots up to show you. I am running my own two stage heat exchanger setup with, two 400cfm fans, Cm30 and a 1 gallon resivour. I need to put some ice in there and see what the temps drop too as well. It will be interesting to see what the temps are when I get my Code3 midsized pulley, since this combo should be comparable to the 181.
