Old Feb 10, 2009 | 07:26 PM
Forza1's Avatar
Forza1
Default re: HID Install Lows and Fogs with Pictures
OK, maybe I'm daft, but I'm having a hard time with these two steps:
Removal of old bulbs
  1. First, and some find difficult, is pulling the connector from the back of the bulbs. If you look closely, you will see an "H" shaped area. I used a medium sized 45 deg bent-nosed needle pliers to grab the center of this "H" and pulled straight back with a little rocking action. DO NOT TWIST! DO NOT PULL ON THE WIRES! It comes off, but can fight a little.
  2. Next, undoing the bulb retaining clips is for some a bit baffling. On the low beams, the clip clamps at the bottom and swings UP. Press the very bottom of the clip and push to the side to unhook it from the retainer. Remove the bulb. Repeat for other side.
What are you talking about removing the connector? I have two wires that appear to have spade connectors into the back of an H7 bulb. Are they going into the connector?
For step two, I can unhook the clip OK, but how do I removed the bulb? Does it go through the clip? Or does the connector first have to be removed(step 1) to get the bulb out?
