Old Feb 10, 2009 | 11:30 PM
  #49 (permalink)
SLK32Germany's Avatar
SLK32Germany
Default Re: Pictures from the Track Yesterday
Originally Posted by SRTpowa
I had the computer hooked up the other night and was seeing 97-105 on WOT bursts, but it was 40 degrees. I will see if I can get do some screen shots up to show you. I am running my own two stage heat exchanger setup with, two 400cfm fans, Cm30 and a 1 gallon resivour. I need to put some ice in there and see what the temps drop too as well. It will be interesting to see what the temps are when I get my Code3 midsized pulley, since this combo should be comparable to the 181.
Congrats! These are some very good results. I have also a complete new IC-System in the works with new IC,HE and some other things. I am curious what this will do with my 185mm Pulley-Ratio...
