Old Feb 11, 2009 | 07:58 AM
waldig's Avatar
waldig
Talking Re: Hey Woody A PCV?
Pardon me for going GM on you but I dont understand the question. The vent can inputs are connected to both valve covers and then after ""filtering"" the output is fed to the stock intake on the throttle body. My Can photo may mislead you as to the routing of the individual hoses, one to each cover and the outlet to the throttle body. Dont let this out but the can is divided vertically and the gasses have to go down and back up thru several stainless media pads / baffels before being released to the outlet pipe.
The driver valve cover has some interesting piping and you can see the actual passways in my photos.
To see whats up I had taken off the driver side cover and did a photo on the underside for my records. One hole is well restricted, I believe to not overflow the throttlebody. The amount of air fed into the engine is what controlls the speed of the engine. Never attempt to start up an engine without the restriction of a throttle body or youll get an uncontrollable thing this side Helln.
Be Well, Woody
