Re: Hey Woody A PCV?
Originally Posted by Bulldogger
I know how to do the catch can, if you notice they plug off the second vent on the driver's side valve cover. I would think you still would want to use the vent to relieve pressure especially since a lot of us are running more boost then stock. I have a oil catch can that has a filter on top, different then the one woody designed which reattaches to the throttle body and helps create vacuum in the system. My JAZZ set up I'm doing a little different. I'm blocking off the throttle body and running all PCV venting into the can.
Bulldogger - you are correct - either way will work - but most air/oil separators don't facilitate the larger hose that connects to the Y-pipe.
The way you are routing your JAZZ setup is the best way to go IMO but won't pass CA Smog inspection.
The JEGS unit I used has an internal filter but doesn't accommodate the larger breather hose so I decided to just block off mine
