the easiest way to disable the chime:
begin by moving the drivers seat forward & up as high as possible... the wire is easier to access from the rear of the seat... it is clipped onto the far back side metal seat frame edge under the seat... held in place by 2 metal tab clips... release the clips and you will have nearly a foot of wire to work with. a flash light will aid... carefully cut back the plastic sheathing... 3 wires will be exposed... snip the brown wire and the chime has been eliminated w/o any side effects. tape the wires back up with electrical tape and re-secure with the clips.
_________________________________________________
here are some pics with the drivers seat all the way forward and in its highest position.
2 clips attach to this metal rail...
the circled area is where i cut back the plastic sheathing and sniped the brown wire... needs covered with electrical tape...
the clips (2) that hold this very long wire under the seat are located on the underside metal frame toward the back edge (slip off rail)... remove both clips & you will have 12" of wire to work with. carefully cut back the plastic sheathing and snip the single brown wire (3 wires total)... tape wire with electrical tape and reinstall... you'll realize how simple it is once you do it.
