Originally Posted by Veloce
Drop it down the side center panel...in the passenger compartment to the left just above the net and this side of the net is a plastic "crease" You can create a hole here that cannot be seen and you can then keep the USB in the net.
You don't need to create a hole..
You can run the cable without drilling holes in many spots. Most notably where the two console pieces overlap (the thick plastic ones.. hard to describe) you acn lift your hand up and feel, you can route a wire in between those to the back of the headunit..
