Old Feb 16, 2009 | 05:51 AM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Is there a tutorial online that shows how to manually change oil on the Crossfire?
If you have a jack and jack stands you can remove the bottom panel (4 bolts) and drain like a conventional car via the drain plug. You get a lot more oil out this way anyway. Also, don't forget to loosen the oil filter to relieve the system pressure and drop another half quart or so.
