Old Feb 16, 2009 | 10:29 PM
jturkel's Avatar
jturkel
Default Re: Did you replace your crank bolt when you installed your pulley?
YES!!!! ALWAYS REPLACE THE CRANK BOLT WHEN REINSTALLING OR INSTALLING A CRANK PULLEY!!!!! if you dont, it will not be installed correctly.....the crank pulley must be tqed hard and the bolt is only good for one usage.....if you dont,you may end up with a wobbly crank pulley and a broken main seal....it happened to me for this reason
