Old Feb 17, 2009 | 06:51 PM
Moparrbust's Avatar
Moparrbust
Default Re: Did you replace your crank bolt when you installed your pulley?
The OEM crank bolts are $5/each retail.................and should be replaced. Those that reused the old one, go buy a new one and put the two side by side before reinstall of new bolt and you will see that the old one is slightly longer than the new(because it stretches when torqued).
