Re: OEM NAV installation problem,...help please!
All I know is I followed those instructions for my 2004 and the wiring is most definitely there as documented. I can't say for sure but generally, on something like this, it's rare (though not unheard of) for the harness to change from year to year on a car like this that is fundamentally the same through the entire run.
Note also that the drawing is dated Nov 3 2005 which tells me that cars made around that time would probably be wired that way. Which suggests this drawing may apply to cars as late as model year 2006.
I will tell you that I had to unwrap the tape bundle to be able to see all the wires. Additionally, what helped me to confirm on the radio plug for the Speed signal, was the pin location for the wire. Take a hard look at that wire with a bright light and glasses (if you need them for reading).
