Originally Posted by kurtisberry
The seat heaters draw too much current when cold. I hold the button on until the light stays on. You will see each blink get longer as you hold it until it stays on. Works for me whenever it is below 20. Ten degrees is about 30 flashes, 15 degrees is about 20 flashes and 20 degrees is only a couple flashes. Or you can wait until your butt heats up the seat, about five minutes.
What Blinking? when I turn on the seat heater, the LED on the switch has
allways been solid red. It doesn't seem to matter on low or high temp range when both LED's are lit . Does this have anything to do with model year? Mine is a late 2007 only 100 #,s from an 08. I live in Iowa and have had plenty of cold morning starts, many below zero with no blinking.
