Old Feb 18, 2009 | 12:05 PM
MikeR's Avatar
MikeR
Default Re: Crankshaft Position Sensor
Do you hear the fuel pump run when you turn the car on? You should hear it for a few seconds. You can check to make sure you have fuel at the fuel rail by taking the cap off the end on the front passenger side. Then press in on the check valve and you should have gas coming out. Make sure you have a towel or something there to catch the gas.
It is odd that it only cranks 3 times and then stops and has no CEL codes.
MikeR
