Yikes ! Replaced the RCM and CPS and still no crank-no run ???
Check the connectors for the RCM, battery connections, ground connections, go back to the basics ! Eliminate the obvious !
Also be very careful checking the fuel rail !!! It will be under pressure.....no sense gettin dowsed with gasoline !
Good Luck !
