Old Oct 21, 2004 | 10:04 AM
Dan Root's Avatar
Dan Root
Banned
Default Re: Complete Break Down Of The Stock Intake
After talking to an engineer regarding are intakes and filters my conclusion was if you live in a hot climate over 80 degrees or drive in hotter areas that moving the XFires intake off the top would help more than less restricted air intake ,and the gain should be around 10 hp.Cleaner air filters and cooler weather would help to produce about the same,So I'm moving to Alaska ,but I may loose all that performance to less traction !
