Old Feb 19, 2009 | 09:05 AM
BoilerUpXFire
Default Re: HELP!! 20" wheel issue
why do you need 2 seperate threads? that one is the the same thing but people responded to it.
I created the second because I found more info on the issue (that I included) and I realized that there was a place specifically for wheel and tire issues (I am new to the forum, my apologies). Certainly not because I did not like Max's answer, quite the contrary. As I said, I have never used spacers before and with all the issues I have read through on here, I was hoping someone would have the knowledge to answer my questions, because I do not and have not been able to locate the answer myself. I have found great info on spacers, offsets, fitment, etc. but with my front rims being 20x8 with a 38 offset and running 235/30-20s, I am hoping someone can tell me if a 5mm spacer will work and what length bolts do I need?
If not, I am certainly proceeding down other avenues to try to get the same info, but I figured if someone on here knew, or had done it, they would be able to tell me. Thanks guys.
