Old Feb 19, 2009 | 11:45 AM
BoilerUpXFire
Default Re: HELP!! 20" wheel issue
Max, much obliged for the info, I owe you a cold beer or two. Based on the calculators I have found and numbers I have ran, I am thinking a 5mm spacer will work also. From my research I have found that everyone says if you are going to do spacers, buy good ones and make sure they are hub centric. I have scoured and found an Eibach Pro spacer that is 5mm and hub centric from a company in Michigan. The part number is EIB90.1.05.014.1 and here is the link:
http://www.discountperformanceautopa...hk=1&Itemid=37
They are reasonably priced at around $75 for the set and after speaking with a custom wheel guy, this is what he recommended.
Any advice before I proceed further?
