Re: Oil Change with Topsider or similar
It's so easy to just drain it. I've heard pro's and con's on exactly how much "stuff" the topsider actually gets out so I'm happy to spend a few minutes under the car and use the drain plug method. It does help if you have a garage, hydraulic jack and jack stands. If you do drain from the pan jack up the drivers side of the car. The drain plug faces the passenger side.
Pat
