Re: How Many Qtz Of Oil???
It uses Mobil 0-40 synthetic. The capacity is 8.5 qts. but only fill it back up with 8 qts. and then check the oil level. Overfilling is worse than being slightly under. There is a oil level sensor that lets you know if the engine oil level is low or high as described in the Owners Manual (or you can always use the old fashion dipstick method).
