Old Feb 22, 2009 | 09:08 AM
Iamfink2's Avatar
Iamfink2
Default Re: Transmission issue
Originally Posted by JGatormann
The transmission in my 2005 has slipped into neutral on hard acceleration and/or hard braking. I have to shift to neutral, shut off the car, then restart it. Very dangerous on entry ramps to x-ways!
Anyone else having this problem???
Jim Borgmann
Miami Springs, FL
Do you have an automatic and if so do you have a sprint booster installed? If you do its probably the sprint booster causing it. I've had the same problem and it will only happen when you hit the kick down switch on the floor.
