Old Feb 24, 2009 | 10:13 AM
cruzinquick's Avatar
cruzinquick
Default Re: New Member and Owner with Belt Question
Quick question are you in 1 or D? Definately turn off traction control. Doesn't sound likes its your IC if you only went 2 miles. If so when you search you'll see the instructions on how to change the pump. The johnson will require modifying your bracket and hoses. The ford lightning bosch pump for $80 is about at plug and play as they get. They don't fail anymore than the johnson will in a few years. The pumps fail because they sat long enough for the plastic part inside to dry and crack. The motors inside have yet to be posted that a motor of the pumps has failed. I'm sure anyone can open it up and put 12v and it will spin.
