Old Feb 24, 2009 | 10:54 AM
onehundred80
Default Re: Do daytime running lights help keep the headlights from fogging?
Originally Posted by corfire
I think I finally got them dry inside. I think that I will be able to come up with a simple mod (using a relay) to keep the lowbeams on with the ignition. This would be a poor mans version of DTR's. I understand that in order to get factory DTR's they have to change out the light switch module and reprogram??
The wiring diagrams do not mention DTR's, and there is no wires going from the `off'' position on the switch. So I imagine that there is a different switch, this switch is mentioned in converting US spec cars to Canadian specs.As to programing changes I cannot think why that would be needed if the switch was hard wired to put on the lights.
The simplest way to do it would be to put on the lights, that way no stealership could say you had interfered with the wiring, and put the solenoid on after the warranty has expired.
