Old Feb 24, 2009 | 12:24 PM
240M3SRT's Avatar
240M3SRT
Default Re: New Member and Owner with Belt Question
What plastic piece breaks? Why wont the spinning motor pump fluid...unless your saying the plastic pieces is the impeller and it just sits there as the motor spins?
Originally Posted by cruzinquick
Quick question are you in 1 or D? Definately turn off traction control. Doesn't sound likes its your IC if you only went 2 miles. If so when you search you'll see the instructions on how to change the pump. The johnson will require modifying your bracket and hoses. The ford lightning bosch pump for $80 is about at plug and play as they get. They don't fail anymore than the johnson will in a few years. The pumps fail because they sat long enough for the plastic part inside to dry and crack. The motors inside have yet to be posted that a motor of the pumps has failed. I'm sure anyone can open it up and put 12v and it will spin.
