Re: A STRANGE FIND.... possible error in owners manual
I didn't check my actual manual. I used the online manual which was for a 2004 crossfire. I have a 2005 base coupe.
I suspect everything works as it should and there isn't a problem. I used a wet paper towel (not dripping wet--more damp) and wiped around the control. I then went to operate the mirror and it moved for a second and stoped. I assumed it got wet and blew the fuse. I eyeballed a few fuses and everything looked ok. I pulled out compartment 6 (which I assumed was for the mirrors) and it is a 5 AMP. It is toasted! I am guessing replacing the fuse will fix my problem. But now everyone is showing different compartments in their owners manual. Which one is correct?
