Old Feb 24, 2009 | 02:44 PM
GDC-SRT's Avatar
GDC-SRT
Default Re: A STRANGE FIND.... possible error in owners manual
Originally Posted by blackcrossfire07
I didn't check my actual manual. I used the online manual which was for a 2004 crossfire. I have a 2005 base coupe.
I suspect everything works as it should and there isn't a problem. I used a wet paper towel (not dripping wet--more damp) and wiped around the control. I then went to operate the mirror and it moved for a second and stoped. I assumed it got wet and blew the fuse. I eyeballed a few fuses and everything looked ok. I pulled out compartment 6 (which I assumed was for the mirrors) and it is a 5 AMP. It is toasted! I am guessing replacing the fuse will fix my problem. But now everyone is showing different compartments in their owners manual. Which one is correct?
Should be the one you first mentioned drivers side under hood!
