Originally Posted by wicker75
Can anyone help me? My 05 coupe will start, but will only run for about 10 minutes and then shut down. It will not start up again right away. I have to wait about 30 minutes and then it will start again, but again will shut down. Can Someone give me a clue what is causing this?
Dylan-
I assume that you do not have any check engine lights, so if not I would assume that you possibly have either a clogged fuel line or filter.. It definitely sounds like a fuel issue with the limited data.
However, you may also have clogged injectors or something that could be a tad more involved.
It is probably not an option to get it to the dealer but when this happens are you going at a pretty good speed?
Have you changed the fuel filter and is your air filter clean?
