Thread: Newb Questions
Old Mar 1, 2009 | 11:07 AM
jgreen's Avatar
jgreen
Default Re: Newb Questions
Originally Posted by 007_MI6
Here is the process to reset the FSS if you need to. I got it first try, but I have heard it can be really tricky.
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1. Move the ignition switch to the “RUN” position.
2. Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second. The display for the FSS service
request is activated for 10 seconds
3. During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position.
The FSS service request will continue to be displayed.
4. Press the reset button for the trip odometer and hold.
5. Move the ignition switch to the “RUN” position
6. Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display.
The tool symbol should disappear at this time.
Hi Thanks for the information, When I did my first oil change (at 2,260) I reset the FSS but, now its shows 2 wrenches and 7000?? why?
