Old Mar 2, 2009 | 02:51 PM
cross><hair's Avatar
cross><hair
Default Re: What could this be?!?!?!
Originally Posted by 70GT6
I heard mine at steady highway speed, only at that speed nothing at idle and nothing at higher rpms.
Clearly not a whine of the SC in my case.
If I had to describe it - it had an almost electronic pitch - I thought something like the radio was going bad.
If the installer over-tightend the idler you could have this issue - that is what was causing several of the bearing failures. (At least, that was one of possible causes of bearing failure)
Maybe you are lucky and it is the intake.
Do you know what the torque spec is on the idler pulley?
