Originally Posted by bigbengt67
Well, I think my intercooler pump died last week so I took the car in for some work today. Here's what I'm getting done:
1) New IC pump
2) Door grab trim is peeling and slicing fingers
3) Lots of oil on the passenger side valve cover- I forget, is this a common problem? I think the gasket is bad.
4) Broken headlight mount tab-hopefully I get a new headlight and half my hazy headlight problems will be gone.
5) Click noise when I turn the wheels to full lock, I think it might be a tie rod or ball joint issue.
Hopefully all will get fixed under MaxCare, until then I've got to deal with a Dodge Caliber rental again...
That stuff should be covered. I don't know if it is a common problem , but I had both valve cover gaskets replaced a couple of months ago under factory warranty.
