Old Mar 3, 2009 | 06:38 AM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: rear bottoming out??
~ on the factory rear shocks there is a rubber bump stop (located on the shock piston/shaft)... when adding lowering springs these need to be trimmed down... this will eliminate the feeling your experiencing. you will have to remove the rear shocks in order to complete the trimming. a simple task with a few hand tools.
