Old Mar 3, 2009 | 09:43 PM
onehundred80
Default Re: Can we find solutions to headlamp problems?
OK, if the lights are on then it is good that there is enough heat to melt the ice which would form in the cold weather you/we are having. The question is if the DTRL's prevent this moisture under normal circumstances, hopefully it does, when water is present it may take a while for them to dry out.
The other question is would 3m film over the lens prevent or decrease this oxidation/hazing. I have had two Chrysler's, one lens was very good with minimal hazing and the other was the worst I have ever seen, it would haze over badly in a few weeks. It all depends on the resin used. My current 300 is very good.
