Old Mar 3, 2009 | 10:11 PM
Moparrbust's Avatar
Moparrbust
Default re: Battery Replacement
Originally Posted by kapium
You could just get the OEM battery from your local Mercedes-Benz dealer. It'll probably run you $125 and you're guaranteed to get the right output / size. I just had to replace the Batt in my C32 and it was only $125. That's less than almost any store carrying a compatible aftermarket. That's most certainly what I will do when mine gets flaky. The electrical systems in Mercedes-Benzes are so finecky it makes a certain amount of sense just to get the original design-spec battery. Not saying that you can't find a comparable one, but it'll save you a lot of effort.
Also, on that same note, if you need OEM parts for the crossfire and need to pay for it out of pocket, you may as well get those from Mercedes too, they are much cheaper than from Mopar. Nearly every part on our cars has the Mercedes part number stamped on it, just call up the dealer and ask for it. Almost everything will cross-ref to a 2004 SLK. Part numbers will start with "A 170 ..."
The main reason I won't go with an OEM battery is they are too damn HEAVY. I'm tired of lugging around a 75(ish)lb battery when I can get a fancy CF Braille one that has more power and weighs 18lbs. That's the equivalent of adding 4-5rwhp to the car and getting very slightly better gas mileage, weight transfer and handling due to the weight loss.
Also, I buy all of my engine parts directly from the local M-B dealer..................that's where the Chrysler dealer's gonna order it from before they mark it up even more and sell it to you anyways.
