Originally Posted by jonnyangel04
I can attest that this job is a 100 percent struggle. We worked at it for awhile and struggled. We ended up having to do the cut and weld method with a tube inside a tube. There is a how to on here somewhere as far as making copies of your template and sending them to us YOU WOULD BE A HERO lol
Hello..You must have been installing the factory Crossfire OEM Roadster 6 tab bars. The ones I installed are the 4 tab MB Roadster bars. If anyone orders the part number RB-SLK from Autogrimming, I can make a light roll up paper pattern copy from my thick cardboard pattern to mail out. Don't know if this pattern will work with a different brand bar? There's some plastic interior trim pieces that are a little tricky that needs to be removed to get to the roll bar bolt area. You don't need to take the carpet out. I spent a day taking the bars in and out several times and making patterns. I now think I could do the job in 2 hours. Squirrel Crusher
