Use a Torx screwdriver #9, not a Phillips unless you use a Phillips screw. These screws mess up real good if you use the wrong driver.
Huh, the one base Crossfire I worked on had little phillips screws in it............must have changed them out. I know M-B uses torx on almost all of their cars and Chrysler usually puts cheap azz phillips instead.
