Originally Posted by billangiep
If you haven't already you might check the batt. terminals for corrosion, loose wires from the alt. ect. Also depending on the age your battery it may be at the end of it's life?
Bill,
Shouldn't be the battery should it? Should be powered by the alt while running. If the alt is being over tasked it wouldn't be able to charge the battery and then your electrical system might suffer but I'd expect to hear this problem a lot if the alt's aren't very powerful.
Maybe it's just that your alt is failing?
My two cents.
Dh
