Originally Posted by blackcrossfire07
Thanks guys. I am going to peel it and sand it. Maybe I will get some of that plastic/metal sealer and touch it up. I think the water sitting in there caused problems so I want to seal it up.
You might want to take a air gun blow out the drain, if you didn't know there is a drain on each side and water will only stand in the cutout if it is plugged up, it drains out by the release handle on the rear hatch on a coupe same place on a roadster only not a hatch a trunk.
Paul
