Re: Headlights fogged over
Man I missed my calling, I should be in the headlight polishing business. 90 bucks????? Here are two fixes for you. Both utilize Meguiars products. Meguiars makes a kit of which the key component is Plastx. The kit from what I have read on these forums works very well. The other fix is simply buy a bottle Plastx, its $7.99. I have found of all the plastic polish/cleaners it works the best. You can either do this by hand or even better buy yourself a Porter Cable buffer (then you can buff your car too!). You can find them on line for 100 bucks. A PC buffer, an orange cutting pad and the Plastx will have the job done in 5 minutes. Your headlight lenses will sparkle. I also wax them and everytime I wash I hit them with the detail spray. You will find that the haze and etching do return, just repeat the procedure and you will be fine. $90 bucks for 5 minutes work? Sounds typical of a dealer.
