Welcome to the forum!! It's good to see another SRT in Pennsylvania. I'm clear over by Ohio (last exit on I-80 before Ohio). I'm no mechanic, but I'd be happy to help. I doubt you want to make the 3 hour drive though.
I see you're interested in about 400 hp. Did you mean 400 at the wheels or at the crank? You might not be aware, but typically car manufacturers state the crank hp, such as 425 hp for the Charger SRT-8. Well all that hp doesn't actually get to the wheels. About 18-20% of it is lost between the crank and the wheels. So wheel hp is typically 18-20% lower.
Also, Chrysler lied when they stated that our cars were 330 hp stock. They're actually 350. (some say 349, some say 354, whatever.) Now, it's a pretty easy jump from 350 to 400. A cold air intake and a pulley should put you right in the neighborhood of 400. Price depends on which CAI and pulley you choose, but guesstimate about $1,000 total if you're buying off-the-shelf products (rather than a do-it-yourself CAI).
Now if you're talking about 400 wheel hp, that's not so easy. Stock our cars have about 290 wheel hp. A CAI, pulley, intake manifolds, and ECU tune should put you near the fuel system's limits of around 380 wheel hp. But along with those performance mods, you'll need some cooling mods to keep that supercharger cool, so add an aftermarket heat exchanger and a better coolant pump to the list.
You can use these price as estimates for those items - note there are cheaper ways, but this is for off-the-shelf aftermarket products:
Cold Air Intake: about $450
Pulley: $650 (smallest) to $850 (largest)
ECU Tune: $500 to $800 (paying anything more than that is robbery)
Intake Manifolds: $1,500 for custom, $750 to mod existing
Heat exchanger: about $500
Johnson Pump: $120
So if you wanted to "super size" your deal, you'd be looking at about $4,220. Then you have the joy of paying someone to install them all.
You can see from my signature which way I decided to go. I would recommend that you start off with a cold air intake. That's good for about 25 whp. It's a nice start, and you may find that's all you wanted. After that, your next step should be a pulley. That should stack with your CAI and add an additional 25+ whp.
No matter how you decide to proceed, talk to some of the vendors:
www.needswings.com
www.letmotorsports.com
www.tvtdesign.com
www.code3performance.com
