Old Mar 13, 2009 | 07:54 AM
Glockhit's Avatar
Glockhit
Default Re: S/W switch effected when a flash mod is done?
Originally Posted by 07bluezx14
I can tell when mine is switched. Can you count how many times it shifts when excelerating? I would assume that if you put it in 4th gear instead of drive, with the switch on w it should only shift 2 times.
Thanks for the input. Actually I have a Limited with auto. I switched back and forth from "W" to "S" while stepping hard on the pedal. I also have a sprint booster. There is a big difference between the two. "S" is much faster. Conclusion..A flash does not change the summer and winter setting when shifting.
