Re: Anyone autocrossing Dot R's?
I haven't been on here in a long time since my Crossfire sold last August. I sold Tim some of his stuff. Basically the setup is the stock size wheels in front and rear. I ran a 1/4 inch spacer up front with the 285/30/18's mounted on the 7.5 inch wheels. The rears were a now discontinued Konig forged race wheel in the stock diameter and width but with a +40 offset. To get a legal offset I got a set of 12mm spacers. So the front track was 1/4 inch wider than stock and the rear track was 1/4 inch narrower. I ran 285/30/18 fronts with 295/30/19 rears. Both Hoosier A6 compound.
Bryan (Nocones) and I each had a set of custom Konis built for the car. You can check with Lee Grimes at Koni as he should still have the valving specs on file. I ran the H&R front sway bar mounted in custom delrin bushings as well. I think with the front camber bolts I managed to get about -1.8 camber in front and I ran a slight bit of toe out in front and a slight bit of toe out in the rear.
Hope that helps. BTW this setup helped me trophy at both SCCA Prosolo's I attended in 2008 and I won the DC Prosolo in 2007 with the car as well. It worked really well for D Stock.
