There's 3 or 4 different threads addressing this problem if you use the
search function. Bottom line is that the window cannot be glued back on. The good news is that one member found a cheaper alternative to replacing the whole top. I believe you may be able to have a plastic window installed to replace the glass. Here's the link......
https://www.crossfireforum.org/forum...***+separating
